Hi
How to remove the write protection in pendrive?
if a flash drive is write protected, then there is nothing you can do and it needs to be replaced. you can replace it with the place of purchase or directly with sandisk support.
here you can contact the sandisk support
http://www.sandisk.com/about-sandisk/contact-us/
