How to recover corrupted files from USB flash drive?
Just wanted to share a frustrating experience I’m going through and hopefully get some advice.
I’ve been using my SanDisk Ultra USB 3.0 flash drive (64GB) for a while without any issues. But just recently, when I plugged it into my laptop, some of the files wouldn’t open. I also gave Windows’ built-in repair tools a shot, but still no luck.
Has anyone dealt with something like this before? How to recover corrupted files from USB flash drive?
Edit: I believe the issue is with the USB drive itself rather than the files. USB drives use NAND flash memory, which can wear out over time due to limited write cycles.
Your SanDisk USB drive shows file corruption. Stop using the drive immediately to avoid overwriting your data. Try recovery tools like Stellar Data Recovery, Recuva or PhotoRec to retrieve your files. You could also use TestDisk if the whole drive seems damaged, and check the drive on another computer to rule out port issues. Once you recover your files, back them up and consider replacing the drive if problems continue.
First, I’d recommend doing a full virus and malware scan on both your USB flash drive and the computer you’re using.
Next, check if you’ve got any backups — especially if you use cloud storage like Google Drive, OneDrive, or Dropbox. You’d be surprised how often people forget that an old copy may still be sitting somewhere safe.
As for recovery tools, there are quite a few out there, but many of the more effective ones are paid (often $50 or more), and even then, success isn’t always guaranteed. So I’d suggest starting with a free recovery tool first.
Hey @HuGo25
I saw the suggestions from @johnjacob and @fayewong—they’ve covered some solid basics like not using the drive, scanning for malware, and checking on another system.
Since your files are showing up but not opening, it looks more like corruption than deletion. In cases like this, recovery is still possible if the data hasn’t been fully damaged. Try using a free data recovery tool that offers a preview option—so you can see what’s still intact before deciding to recover.
Also, testing the USB on a different computer can help rule out any OS or port issues. Hope you’re able to get your files back.
John’s advice is spot on..stopping use right away is key. I ended up using a recovery tool that let me preview the files first before restoring anything, which saved me a lot of headaches. It wasn’t perfect, but I got most of my important stuff back.
Have you tried seeing if the tool can at least preview the files? That usually tells you quickly what’s recoverable.
It can be stressful to recover corrupted files from a USB flash drive, particularly if the data is crucial for research, work, or personal use. Inadequate ejection, abrupt power outages, file system problems, malware, or physical damage are all common causes of USB drive corruption. The files may then become unreadable, inaccessible, or show up as unknown formats.
Basic troubleshooting techniques like Windows Error Checking, CHKDSK, or virus scans can be used to resolve this problem. These techniques don’t always recover your lost data, though, particularly if the corruption is severe. The BLR data recovery tool is very beneficial.
A specialized data recovery tool thoroughly examines your USB flash drive, finds any corrupted, erased, or hidden files, and securely extracts them. You can recover documents, videos, images, and other files without changing the original data by using a program like Data Recovery Wizard or any other sophisticated recovery software. It supports multiple file systems (FAT32, exFAT, NTFS) and retrieves files even from badly corrupted or formatted USB drives. Users have the best chance of recovering their data safely and promptly without the need for technical expertise if they use a reputable recovery tool.
Your take on NAND flash wear-and-tear is spot on—even a reliable series like the SanDisk Ultra can hit its physical limit after a lot of read/write cycles.
Since Windows’ built-in tools like chkdsk didn’t do the trick, my biggest advice is: stop any further “repair” or writing attempts. The more you stress those worn-out cells, the higher the chance of permanent data loss.
A few things you could try before giving up:
  • Try a USB 2.0 port: Specifically one on the back of your PC case if you’re on a desktop. Sometimes USB 3.0 power fluctuations can cause read errors, and the older 2.0 ports are often more stable for struggling drives.
  • Switch OS: Try plugging it into a Mac or a Linux machine. Different file system drivers handle “bad sectors” differently and might just let you copy the files off.
  • Check a Pro Guide: If you’re looking for a step-by-step on how to recover those corrupted files, I found a really solid, * detailed guidethat might help you navigate the process safely.
Stop using the drive immediately — any write could overwrite data.
Recover data first: DO NOT run CHKDSK or format.
  • Use free tools like Recuva, PhotoRec, or EaseUS to perform * USB data recovery.
  • Scan the USB drive, preview files, and save recovered files to your computer (not the USB).
After recovery, try repairing the drive:
  • Run chkdsk X: /f /r (replace X with drive letter).
  • If that fails, format the drive (exFAT or NTFS).
If physically damaged or not detected → professional recovery (DriveSavers, etc.).
You may implement these steps to repair your inaccessible USB flash drive and recover the lost data:
Method 1: Fix File System Errors via CHKDSK
This approach will repair errors without formatting or deleting your files, but it does not work on RAW drives.
Step 1: Plug the USB drive into your computer.
Step 2: Type cmd in the Windows search bar, right-click Command Prompt, and select Run as Administrator.Step
3: Type chkdsk *: /f /r /x (replace * with your actual USB drive letter, such as chkdsk G: /f /r /x) and press Enter.
Method 2: Format the Drive via Diskpart
In case CHKDSK fails due to severe drive corruption, you may try this method; but this process wipes all data.
Step 2: Type Diskpart in the search box, right-click it, and select Run as Administrator.
Step 3: Type List disk and press Enter to identify your USB drive number (e.g., Disk 2).
Step 4: Select your disk, then type format fs=ntfs (or use fat32 or exfat) and press Enter to format the drive.
Method 3: Reinstall the USB Driver via Device Manager
Step 1: Press Windows + X keys and select Device Manager.
Step 2: Expand the Disk drives section, right-click your removable USB flash drive, and click Uninstall.
Step 3: Click OK, safely unplug the USB drive, and restart your computer.
Step 4: Plug the USB drive back in; Windows will automatically reinstall the driver.
If you want to save files from an inaccessible or corrupted drive before completely resetting it, you need to download, install, and launch professional-level data recovery software on your PC, select the corrupted USB drive, click Next to scan for lost files, preview the results, and click Recover to save your files to a safe location.
Once files are safe, right-click the USB drive in This PC, select Format, or use Disk Management or Diskpart to completely reformat the USB drive. Read also : How to Fix Corrupted USB Using CMD?
