Hello, I am using a 32GB SandIsk USB Drive, I plugged it in a linux machine and I am not able to see anything, I plugged it into a windows machine and it says to format it, but If I format it then how do I recover my data, please tell how do I recover my data from the usb?
Plug it into the Windows machine, open a Command Prompt window and run a CHKDSK command for the USB’s drive letter. You may have to Safely Remove the drive and reinsert it after the CHKDSK has been run.
Firstly, you’d better do not format the USB. Try following methods…
- Go to Disk Management to see if the USB is there, and if it is shown as RAW. If so, you need to format it.
- Check if the USB’s file system is not recognized by Windows, like Ext2/3/4. Just convert file system with Partition Wizard.
- If it has bad sectors, try running CHKDSK to fix error.
If these tips don’t work, you have to format the USB, and then run a data recovery program (many choices from google) to scan the USB and recover data as soon as possible.
Kathy makes a good point TheBlapse. If you formatted the drive in a Linux machine it may very well be formatted as a Ext2/3/4 drive and that is indeed unreadable by Windows but the files are still there so don’t format the drive in Windows.
Find another Linux system or see if the app Kathy suggested. The free version doesn’t look like it works with Linux file systems but the $159 Professional version might.
The EaseUS Data Recovery Wizard’s $69 version may work with Linux formatted drives but I didn’t see it referenced in the free version.
Let us know what works for you.
There are new options for accessing linus file systems in windows linux sub systems for windows.
Can also just install a virtual machine as well.
#SanDiskUserRewards
Using a virtual machine requires the user learning how to use a linux.
Does the WSL 2 system support booting ext4 drives?
And does WSL 2 support reading ext2 drives?
I understand that you are having trouble recovering data from a corrupted SanDisk USB drive. I am sorry to hear that you are experiencing this issue.
I would recommend using Stellar Photo Recovery Premium to recover your data. Stellar Photo Recovery Premium is a powerful data recovery tool that can recover data from a variety of storage devices, including USB drives.
To use Stellar Photo Recovery Premium, simply follow these steps:
- Download and install Stellar Photo Recovery Premium on your computer.
- Connect your SanDisk USB drive to your computer.
- Launch Stellar Photo Recovery Premium and select the “USB Drive” option.
- Click the “Scan” button to scan your USB drive for lost data.
- Once the scan is complete, you will be able to preview the lost data.
- Select the files that you want to recover and click the “Recover” button.
Stellar Photo Recovery Premium is a paid software, but it offers a free trial that you can use to test the software before you purchase it.
I hope this helps!
Here are some additional tips for recovering data from a corrupted SanDisk USB drive:
- Do not format the USB drive. Formatting will erase all of the data on the drive, making it impossible to recover.
- Do not write any new data to the USB drive. Writing new data can overwrite the lost data, making it even more difficult to recover.
- Use a data recovery tool as soon as possible. The sooner you start the recovery process, the better the chances of recovering all of your lost data.
Lizzy are you recommending the $69.99 version or the $99.99 version of the Stellar app? Are there discounts for seniors?
Hi, when you will check Stellar’s website, you will get a free edition too. You can go for that one which can recover the limited number of files and you can search for the discount codes for the full edition on the website itself.
Did you encounter the following error message when you connected the USB drive to the computer: “You need to format the disk in drive before you can use it”?
If so, you can try some basic troubleshooting steps before formatting the drive. For example:
- Try different USB ports or connect to another computer
- Scan the drive with antivirus tools
- Update/reinstall the device drivers
- Change the drive letter
- Use the CHKDSK command to repair logical corruption
If all else fails, you can use free data recovery software or hire a professional to recover the files for you. I usually don’t recommend buying commercial data recovery software since there are great free tools like Recuva and TestDisk available. However, some commercial software comes with advanced features, like letting you preview files before recovery, which free tools don’t offer. Do your homework before making a purchase.
I’ve tried easeus data recovery software, and it has helped me recover lost data from the drive ![]()
Disk Drill.
Free download and “Free data recovery of up to 500 MB”.
10-15 yrs ago that may have been sufficient but not now days.
I belive the same applies to Recuva.
To recover modern day drives and files expect to need the pro versions which are $70+.
If you have a USB drive that doesn’t reveal data on Linux and either asks for formatting on Windows, there might be problems with the file system. First, on Linux, it is possible to use the lsblk or fdisk -l command and check if the drive is identified. If so, you can use mount to give a try to the manual mounting. However, the best way to do this is by using the diskpart command on Windows and assign a drive letter.
If you want a simple and basic recovery then the BLR Pen Drive Data Recovery Tool is perfect for you. There is a special feature of scanning for lost data that does not overwrite your files so that you can accomplish the recovery without overwriting the lost information.
Step 1: Basic Checks
Try a different USB port/PC — Rule out a faulty connection (e.g., switch to a rear motherboard port).
Open Disk Management:
- Press Win + R, type diskmgmt.msc, and check if the USB shows as RAW or Unallocated. If the capacity looks normal (~32GB), proceed to recovery tools.
If it says No Media — This might indicate physical damage (see Step 3).
Step 2: Use Free Recovery Software(2gb data for free recovery and upgrade to pro for unlimited data recovery)
Tool Recommendations:
Data Recovery Wizard (Beginner-friendly, free version works great)
How to Use Data Recovery Wizard:
1.Plug in your USB → Launch Data Recovery Wizard → Select your USB from the dropdown.
2.Click USB Drive → Scan the whole drive and wait
3.Preview lost data → Recover → Save them to a different drive (not the USB!).
Step 3: Last Resort for Hardware Failure
If the USB isn’t detected at all or makes strange noises:
Stop using it immediately — Continued use could overwrite data.
Consult a pro: Look for local data recovery services (they’ll disassemble the USB in a cleanroom).
Critical Notes:
Do NOT format the USB — This reduces recovery chances.
Avoid writing new data to the USB until recovery is done.
So, did you format your USB flash drive anyway?
You can apply professional USB recovery software to recover missing files from a USB drive or formatted USB flash drive. It’s still possible to retrieve data from a quick formatted disk if you haven’t using it after the formatting.
In this situation, do not click ‘Format.’ The prompt from Windows indicates that the PC successfully detects the USB drive’s hardware, but the file system itself is corrupted—often appearing as a ‘RAW’ format in Disk Management. Your data is still completely intact inside the drive. The best approach is to use professional recovery tools to bypass the corrupted file system and extract your files. Once your data is safely backed up, you can format the USB drive to make it functional again.
Also read: Fix The Error ‘You Need to Format The Disk in Drive Before You Can Use It’
