How to recover corrupt files on SD card
I have files on an SD card that show thumbnails and data recorded but cannot open them. I can open some but not the majority. I have tried disk drill to recover but nothing. Photoshop says it cannot open that " Could not complete your request because Photoshop does not recognize this type of file.
help! how can I recover these images.
Hi @dorifitz,
What is the format of these files? When selecting data recovery software, you should check whether the tool supports the file types you need to recover. Disk Drill only allows users to recover up to 500MB of data for free. Try a few free data recovery software options; they might work. You don’t have to worry about wasting money before they successfully recover your files.
Since Disk Drill hasn’t worked and Photoshop can’t recognize the files, you could try using alternative recovery tools like PhotoRec or Stellar Photo Recovery, which specialize in recovering and repairing image files. Additionally, check if the file extensions are correct or attempt opening them in different software like GIMP or IrfanView to see if it’s a format issue. If the files are corrupted, you could also try a tool like Stellar Repair for Photo software to repair damaged images.
@dorifitz,
Have you opened a support case yet? If not, you can get more information by reaching out to the SD Technical Support team for the best assistance and troubleshooting.
Try to check if the files have the correct extensions like .jpg or .png. You can also try opening the images with viewers like IrfanView or XnView. If the files are damaged, use repair tool to repair them or use any recovery software for it.
Sometimes files can become corrupted during transfer from the SD card. If the data is still there but files are partially broken, use a different card reader or USB port.
Since Disk Drill didn’t work, a different recovery tool is worth trying. I would recommend Stellar Photo Recovery software for your images and photoshop files. You can also repair your corrupt files from this tool.
Read here: How to Recover Photos from a Corrupted SD Card?
What format are these files? When selecting data recovery software, make sure the tool supports the file types you need to recover.
I suggest you calm down and check all your backup drives. If you don’t have a backup, try using some reliable data recovery software.
If that doesn’t work, consider reaching out to professional data recovery services. Just remember not to use the SD card for storing or transferring any new files until you’ve recovered the old data.
For those images you cannot open because of corruption, it’s recommended to apply a photo repair tool to fix the corruption immediately. However, things can be easier if you have backups.
Sounds like an old card that was left out too long. This is a known problem with NAND as it tends to rot away faster than hard disks.
