Experiencing slow speeds on your Extreme Portable SSD can be frustrating, especially when you expect fast, consistent performance. Several factors—such as outdated firmware, incorrect USB ports, or file system issues—can cause noticeable slowdowns. Start by checking your connection. Make sure the SSD is plugged into a USB 3.1 or USB-C port, as using slower ports will limit transfer rates. Also try switching cables because worn or non-certified cables often reduce performance.
Next, update your SSD’s firmware using the SanDisk SSD Dashboard, which can significantly improve speed and stability. You can download it from SanDisk’s official tools page:
https://kb.sandisk.com/app/answers/detail/a_id/15134
If your drive is nearly full, free up at least 10–15% of space to avoid performance drops. Running a disk check or optimizing the file system can also help. On Windows, use the built-in “Optimize Drives” utility; Mac users can run First Aid through Disk Utility.
Finally, make sure your system supports UASP mode, which enhances SSD performance. If issues continue, refer to SanDisk’s troubleshooting guide:
