Slow Speeds - 1TB Extreme Portable to SanDisk 2TB Extreme PRO
Transferring large number of RAW and JPG image files from a 1TB Extreme to a 2 TB Extreme Pro drive.
2TB Extreme Pro (formatted NTFS and empty) connected to USB 3.2 Gen 2x2 Type-C, 1 TB Extreme USB 3.2 Gen 2.
Using supplied Sandisk cables. Files average around 20MB each - no large video, etc.
93.5 GB took around 45 minutes to transfer - File Explorer shows ~ 32-35 MB/s which I believe translates to 296 MPS.
If correct this is far below the rated speed of both drives - what’s going on?
Try reverting the USB-C cable - worked for me…don’t ask me why.
Do you mean reversing the cable??
Yes, correct - assuming it is USB-C cable - put the end which is in the drive into the computer and vice versa.
I have a 2TB PRO and get those speeds if I use a different cable other than the one supplied. If its not a 10K capable cable I get 45MB/s with the right one I get 1080MB/s. So make sure its the original cable and its in good condition.
Also I would change the device properties in Window Device Manager for ‘Better Performance’ and ‘Enable Write Cache’. Not your issue, but helps speed things up a little.
The rated speeds of SanDisk Extreme drives (1,050 MB/s to 2,000 MB/s) are measured using sequential transfers of single, massive files. Transferring thousands of small files reduces these speeds because advertised rates apply only to single-file transfers, and Windows File Explorer slows down when processing individual files sequentially.
To achieve speeds closer to the drive limits, try these fixes:
  1. Use a third-party file copying or backup utility: Utilities like FastCopy or TeraCopy bypass standard Windows Explorer limitations and handle small-file overhead much faster.
  2. Zip the files first: Archive the folders into a single, uncompressed .zip or .tar file before moving them, and then unzip them on the destination drive.
  3. Use the Command Line (Robocopy): Windows has a built-in tool called Robocopy that handles large batches of files better than File Explorer.
  4. Check the drive formatting: Usually, exFAT drives perform well when transferring a massive number of small files. Additionally, disk cloning software is significantly faster for data-transfer tasks.
Read also: USB Transfer Speed and the Factors That Affect It
