I was just curious to know if anyone knows of a fail safe way to crack open the plastic packaging of these flash drives. It does not matter I’ve got the 4GB, 8GB, 16GB and 32GB models. If you can show me how to open one of them I should be able to open the rest of them. I’ve tried using a precision screw driver set you the ones which are very small but still cannot get the case to open. There out of waranty so no worries there.
I would suggest a sharp chisel and light taps on the side of the case. Another option could be a utility knife’s bade and light taps on the side of the case. A hair drier might soften the plastic but might also over heat the insides.
I haven’t really thought about it. One thing is for sure, you can never repair it. Since the parts is very small and no tool can ever repair that. But it would be a nice view to observe though.
