How do I safely eject iXpand Go from iPad?
1.Since the iPad does not have any safe eject capability, how do I safely eject/remove my iXpand Go from my iPad without corrupting any files on the iXpand?
2. Currently before I remove the iXpand Go, I close the app that was working with it, and I power off my iPad. Is that the safest way to eject/remove from an iPad?
2. Does the iXpand Go have a “Quick Removal” or “Quick Disconnect” capability like SD cards have?
4. Does the iXpand Go use “write caching” or “write back caching” that might cause corruption if the iXpand is removed too soon?
Thinks for any help you can provide!
Hi @Chasb1,
Please refer to the user manual of iXpand drives:
For more details please contact the SD Technical Support team for best assistance and troubleshooting:
