Am sure if you are “with it” my question will seem stupid. I know to eject ixpand from main PC by pressing eject safely… How do I remove ixpand from iPad safely? I’ve search everywhere and can’t find any instructions… Do I just pull it out from lightening Socket? Forgive me for Ming dumb! But don’t want to just take it out, and find out I’ve done it wrong!
As long as the light on the side is not blinking (indicating a file transfer in progress), you’re probably OK with just pulling the lightning cable, but just to be on the safe side you might want to close the app first.
