I have downloaded/installed the Sandisk upgrade software but nothing happens when I insert the Sansa Express (SA) in the USB. According to the upgrade software I should put the player into MSC mode but as far as I know it is not possible with the Express.
The installed version in my one (bought in Sweden/Europe) is 01.01.01E2.
So, questions:
What is the latest firmware for Europe?
How do I manually upgrade the Express?
Does the Sandisk upgrade software really works with Express in MTP mode?
If newer version for Europe is available I want that version. But… the most important is to manually upgrade the firmware to US version (with radio). How??
BR
Fredrik
