How Do I Fix Broken Clip?
Hello.
I accidentally broke plastic clip on mine and wanted to know how this can be fixed:
You ideas are welcome.
Thanks.
If you have the other piece you could try gluing it back. You’d have to ask a hardware store person which glue will bond to the Clip’s particular plastic…
It might be simpler to go to a hardware or grocery or stationery store and buy a small flat clip and glue that to the back. Look at bag clips, binder clips, etc.
Do you think JBWeld Twin Tube will be suitable for bonding stainless steel with Sansa+ plastic surface filed down?
This is what package says:
Use On
  • Automotive
  • Brick
  • Concrete
  • Epoxy & Adhesives
  • Fiberglass
  • J-B Weld
  • Metal
  • And More
Great For
  • Household Repairs
  • Automotive
  • Plumbing
  • Marine
  • Crafts & More
It might be. You could try it. Many who have had the clip break off just use the player without a clip and keep it in a pocket. Some even break off a functioning clip just to get the player to be more compact.
