Help with conversion of Videos
So yesterday i purchased a sansa Fuze. I love that the screen is bigger than my old e250r (loved it too before i crushed the screen) and today i was trying to convert some videos. i loaded the preloaded video in to media info with these results:
General
Complete name                    : C:\Documents and Settings\Luke\Desktop\WAZ.MineToRemember.SansaPlayer.avi
Format                           : AVI
Format/Info                      : Audio Video Interleave
File size                        : 20.0 MiB
Duration                         : 3mn 26s
Overal bit rate                  : 812 Kbps
Writing application              : InterVideo
Video
Format                           : MPEG-4 Visual
Format settings, BVOP            : Yes
Format settings, QPel            : No
Format settings, GMC             : No warpoints
Format settings, Matrix          : Default
Codec ID                         : DX50
Codec ID/Hint                    : DivX 5
Duration                         : 3mn 26s
Bit rate                         : 672 Kbps
Width                            : 224 pixels
Height                           : 176 pixels
Display aspect ratio             : 1.273
Frame rate                       : 20.000 fps
Resolution                       : 8 bits
Scan type                        : Progressive
Bits/(Pixel*Frame)               : 0.852
Stream size                      : 16.6 MiB
Audio
Format                           : MPEG Audio
Format version                   : Version 1
Format profile                   : Layer 3
Codec ID                         : 55
Codec ID/Hint                    : MP3
Duration                         : 3mn 26s
Bit rate mode                    : Constant
Bit rate                         : 128 Kbps
Channel(s)                       : 2 channels
After some tweaking and modifyn in SUPER video, i was able to produce these results with my own video:
General
Complete name                    : C:\Documents and Settings\Luke\Desktop\It Had To Be You.AVI.AVI
Format                           : AVI
File size                        : 18.1 MiB
Duration                         : 3mn 50s
Overal bit rate                  : 658 Kbps
Director                         : created.with.SUPER(C).v2007.bld.23
Writing application              : SUPER(C) by eRightSoft
Video
Format profile                   : Simple@L1
Format settings, BVOP            : No
Codec ID                         : DX50
Duration                         : 3mn 50s
Bit rate                         : 518 Kbps
Width                            : 224 pixels
Height                           : 176 pixels
Resolution                       : 8 bits
Colorimetry                      : 4:2:0
Bits/(Pixel*Frame)               : 0.657
Stream size                      : 14.3 MiB
Writing library                  : SUPER(C)
Audio
Format                           : MPEG Audio
Codec ID                         : 55
Codec ID/Hint                    : MP3
Duration                         : 3mn 50s
Bit rate                         : 128 Kbps
Sampling rate                    : 48.0 KHz
Resolution                       : 16 bits
Stream size                      : 3.52 MiB
Writing library                  : LAME3.96.1
Even though the only difference is the  sampling rate in the audio, i still cant get it to read.
dont tell me about SMC, ive tried it, i have xp sp2 w/ WMP11, the .263? update of SMC , and the new fuze firmware. whenever i try to convert a video it stopps before it hits one percent. n-e-help?  thanx
the only way to transfer videos to the fuze is by using the sansa media converter.  i think its inserting some metadata to the videos that’s why other converter won’t work.
Sometimes it helps to filter the file through another conversion utility, such as AnyVideoConverter first, and then run the new file through SMC.  The extra conversion does reduce overall quality, but even a snowy screen is better than no screen at all, and besides that, with such a small display any reduction in quality will not be so noticeable.
If the screen is snowy, y’all need to move them tennas a bit, or put some tin foil or coat hangers on 'em.
Git one of the kids to move em for ya.
Sorry, couldn’t help it.  Anyone remember the days when Dad’s remote control was asking the kids to rotate the aerials, or the fine tuning, and perhaps the vertical hold knob?  Ah, I can still smell the bakelite and dusty vacuum tubes.  Good times.
Bob  :stuck_out_tongue:
