HELP: Repeated SanDisk V90 Card Failure on Lumix S5 II (Need Real Feedback – Not Basic Troubleshooting)
Hey everyone,
I’m reaching out for some real support and insight. I’ve now had two SanDisk Extreme Pro 128GB V90 SD cards fail on me during a shoot — nine months apart — both under similar circumstances. These are not cheap cards, and the loss of footage is beyond frustrating.
Here’s my detailed breakdown:
Camera & Setup Info
  • Camera: Panasonic Lumix S5 II
  • Firmware: Latest version (fully up to date)
  • Cards: SanDisk Extreme Pro 128GB V90 UHS-II
  • Total Cards Owned: ~15 (all high-end SanDisk V90s)
The Problem (Occurred Twice, 9 Months Apart)
  • Issue: Card corrupts during a shoot.
  • Error Message: “Please insert SD card” appears mid-shoot.
  • Result: Card is not recognized by camera or computer. Recovery software fails to even read it.
Common Denominators in Both Card Failures
  1. Old Footage on Card:
  • I did not format the card before the shoot because it had footage from earlier that day or a previous session.
  1. Frequent Playback During Shoot:
  • I was reviewing and playing back clips often during the shoot.
  • Then switching back and forth between playback and shooting mode — probably 20+ times that day.
  1. Failure Occurred During Transition:
  • Card failed right as I transitioned from playback mode back to shooting mode.
Recovery Attempts (Both Times)
  • Tried 3 different computers and 2 other cameras.
  • Tried multiple recovery software programs.
  • In both cases: Card not even recognized = cannot recover data.
  • Important distinction: If the card had simply been corrupted, I could have used recovery software to retrieve the footage. But because it was a complete card failure, the card couldn’t be read at all — making recovery impossible.
  • The only theory I can come up with is that there may have been some sort of electrical short or glitch when the camera transitions from playback to shooting mode — it’s the only moment that lines up in both cases, and the only thing that remotely makes sense at this point.
  • Conclusion: Not a corruption issue — total card failure.
My Usual Workflow (for the past 9 months):
  • I always use a freshly formatted card before every shoot.
  • I follow best practices with formatting in-camera before use.
  • These two failures are the only exceptions (where I didn’t freshly format before shooting).
My Questions for the Group:
  • Is this a camera issue (Lumix S5 II)?
  • Is it a card brand issue (SanDisk V90)?
  • Or do I absolutely have to freshly format every card before every use, even if the card already has footage from the same camera/session?
  • Has anyone else had issues switching between playback and shooting modes and encountering this kind of error?
Final Notes:
  • All footage was recorded on the same camera and left in the same card. No cross-camera or card swaps.
  • I’ve contacted both SanDisk and Panasonic — both gave me basic troubleshooting and provided no help.
  • I’m looking for real feedback or insights to avoid this happening again.
Any help is appreciated. Thank you!
@rmillervideo
(Get Support for Your SSDs and Flash Products | Sandisk)
Try this one.
(Contact Support | Sandisk)
When I use card based cameras for shooting video I keep a lot of them on hand so that I can shoot and not fight cards
I suggest a USB card reader as these are inexpensive and convenient. I use SanDisk as the cards work fine.
I suspect fakes as the cards I have work fine years old
Hi @rmillervideo,
From what you shared, it sounds like a full card failure, not just corruption. It’s important to always freshly format the card in-camera before each shoot, even if it has old footage.
Frequent playback and switching modes can stress the card too. It could be a rare card defect or a fake card issue, so check authenticity. Less likely it’s the camera if no one else reports it. Rotate cards often and avoid heavy playback during shoots to stay safe.
Right. A full card failure. Just a bummer the card is that “sensitive”.
As far as the card, how do you “check authenticity”? I buy my cards from reputable sources. What identifying markers can I expect?
Also a bummer if I cant use my camera to check my footage. For how much we spend on these things, I should be able to review my footage.
Sadly counterfeiters work hard. I have one old 32GB SD that I use for file history on an old laptop. Periodically I erase the SD card and write zeros so it is refreshed and put it back to work. My Dell XPS 15 9570 has a SD card slot so I put the card there for want of more storage. My Lenovo T14 had a micro SD slot but that machine croaked but I have a USB card reader so I can read any card on any machine.
