Could this be a power issue? I hope I haven’t lost all of my data on my portable external HD?? Thanks for any help with this.
It could very well be a power issue related to the power adapter. Maybe you should try contacting WD’s Technical Support about this. You can do so either by phone or email.
http://support.wdc.com/contact/index.asp?lang=en
Regards,
