I have found some good information on this forum but I have a question I am hoping someone can answer. When I put my 8GB Micro SD card into my player the only way I can get the player to read the card is to hold the card in. Is this normal or should the card fit in the player so I don’t have to hold it in? If it is supposed to fit in snuggly, mine does not. The card that is currently in my player is a PNY micro SD 8gb card.
Are you sure it is pushed in far enough for the locking mechanism to grab and lock it in?
http://forums.sandisk.com/t5/Sansa-Fuze/Fuze-and-micro-sd/m-p/137465/highlight/true#M35663
