When I turn my MP3 on and off there is a green light for a minute and then it works fine. Anyone know whats up ? Thank you for your time…Ray
What version of player and what green light/where?
are you sure that you are using the clip + player? because i heard about an issue with a green screen but on the clip zip player.
Version - V01.01.21A
When I turn the MP3 Player on or off it shows Sansa logo for a sec, then the LCD light turn green for about a minute or so. After that it plays normal. I was hoping someone had a fix for this. Thanks…Ray
I think I am , I have seven of them, One for Rock, Jazz and so on. I wait till Radio Shack has them on sale, they have great sales when they are. But I think the Shack has stop selling them. To Bad I like them allot. Anyway I am going by the picture to see what MP3 I am using. Could you let me know about the issue with the clip zip. Is there a fix? Thank you for you time…ray
I do have a clip not a clip +. Here is how I fixed the problem. I reinstalled the firmware manually from the instructions on the home page. So far ir seems to be working and was easy to do. Have a good day people…Ray
thank you for providing the solution to this post in order to let others know how you resolved your issue.
I think you actually have a Zip, the clip/clip+ don’t even have green pixels.
HAHA your right it is a Zip. All these clips no wonder it took me a while to get my MP3 working right.
I know this is an old topic but it does happen to me on occasion. So I wanted to tell anyone with this how I fix it.
I use my player for audio books. I downloaded from the library and I am constantly adding and deleting files. The adding and deleteing will cause any computer to slow down.
I do get that green screen from time to time. Sometimes it is just for under a minute starting and stopping, which is a bit annoying. But today it turned green while I was listening and did not go away and it was turning off, I gave it over 5 minutes. It took over a minute holding down the on/off to shut off completely.
Step I use to fix.
- To reset (reboot) it may take holding down the on/off for over a minute.
- Plug into the computer and backup anything you want to save.
- Unplug from computer and go reformat
- Plug back into computer and check for firmware updates
- Copy files back.
- Unplug from computer and all should be well again.
