Just started going to sleep today.
I have recently updated to 13.6.6 on my M1 Mac Mini now my external G raif drive keeps going to sleep (didn’t before I updated)
Energy power settings are set not to put HDs to sleep.
Happening when using FCPX with the drive and also if the drive is on without any software using it it will boot up and then randomly go to sleep. If when in FCPX it goes to sleep I can then start using FCPX and it boots up and works again OK. Then after. awhiole boots down and goes to sleep again.
Disk Utilty says the drive is OK.
I cahnged the port of the connected USBc connection on the Mac.
Is there any third party disagnostic software to check the drive?
