G-Raid 2 12TB constantly falls asleep with Macbook Pro M2 (thunderbold 3 connection)
Recently bought a nice G-Raid 12 TB hard drive which is connected directly to a brand new Mac Book Pro M2. Unfortunately the drive constantly goes to sleep mode and shows me the famous mac windmill.
I bought it to work quicker than my older and way cheaper external usb harddisk but this only slows me down. Is this just a setting, does anyone know? I allready set the harddrives to constanty on in the Mac energy settings. Help, please!
Hi @Digitalpunx,
Strange it happened to me too and I invested quite a bit of money and after consultation with an expert consultant!!
On the internet i see many cases with the same problem. First i set my harddrives (on MacbookPro M2) to always on but without result. Then i set my ā€˜turn screen of after … minutes’ to never. So far that solved the issue.
I even tried as an experiment to set ā€˜turn screen of after 1 hour’ and leave my mac for more than an hour, and yes … the problem was back again. A restart will do by the way :face_with_peeking_eye:
If your G-Raid 12 TB hard drive connected to your Mac Book pro M2 is frequently going into sleep mode and causing slowdowns. Ensure that the drive’s sleep settings are properly configured, either through the manufacture’s utility software or documentation. Adjust the Energy saver settings on your Mac to prevent the hard disks from going to sleep when possible. If you are using a USB connection, consider using a powered usb hub to ensure the drive receives sufficient power. It is also important to keep both the G-Raid drive and Mac firmware and drivers up to date.
Regards
If your G-Raid hard drive is going to sleep frequently and causing performance issues on your Mac Book Pro M2, there are a few potential solutions you can try:
Adjust power settings: As you mentioned, you have already set the hard drives to stay constantly on in the Mac energy settings. However, double-check the settings to ensure that the sleep settings are adjusted specifically for the external hard drive.
Use a different USB port or cable: Sometimes, connectivity issues can cause drives to go to sleep or experience intermittent disconnections. Try connecting the G-Raid hard drive to a different USB port on your Mac Book Pro or use a different USB cable to rule out any issues with the current connection.
Install manufacturer-specific software: Check if the manufacturer of the G-Raid hard drive provides any software or utilities for managing the drive’s settings. Such software may offer additional power management options or firmware updates that can help resolve the sleep mode issue.
Disable ā€œPut hard disks to sleep when possibleā€: Go to System Preferences on your Mac, select ā€œEnergy Saver,ā€ and make sure the option ā€œPut hard disks to sleep when possibleā€ is unchecked. This will prevent the Mac from putting the hard drives to sleep.
Use third-party disk utilities: There are various third-party disk utility applications available that allow you to customize power settings for external drives. These utilities may provide more granular control over sleep settings and help you prevent the driver from going to sleep unexpectedly.
Contact technical support: If none of the above solutions work, it’s advisable to reach out to the technical support of the G-Raid hard drive or the manufacturer for further assistance. They may be able to provide specific troubleshooting steps or suggest a firmware update that addresses the sleep mode issue.
Remember to always ensure you have a backup of your important data before attempting any changes or modifications to the drive’s settings or firmware.
