I listen to a lot of audiobooks/podcasts on my 4 GB fuze. I have an 816 GB card installed which I keep my audiobooks/podcasts on, music files on the 4 GB memory, (although this was still an issue before I had the 16 GB card)
The situation; I can pause the audiobook/podcast in mid chapter (wherever), turn the fuze off. When I turn it back on to listen to it, I can resume at the spot where I paused it.
I can even do this on multiple files at one time - for example, if I pause one podcast, skip to another & listen for awhile, & then return to the first one, I can still resume playback on the first file where I left off. Great, right?
Well, here is the problem;
When the batt. needs recharging & I plug it in to the pc - after the charging is complete & I power it back on, all my “paused/stopped” files are reset. In other words, all my paused/stop areas are lost and the file has to be restarted from the beginning.
I hope that makes sense! has anyone here experienced this problem? Is there a way to fix it?
Thanks!
