@ ewelot wrote:
Interesting discussion. Anyone out there who has some numbers on battery life with and without external memory card (e.g. playing mp3 only)?
Not me…my card is always in.
Perfect! You are the one I’m looking for because I don’t own a card.
I get 25hrs of mp3 playback (96kbps, volume level 75% on “Normal” scale, backlight 50% for a total of about 20min). I’m curious to see your numbers soon …
Thing is, I have lots of different file types, and bitrates…so I don’t know how scientific a comparison would be. I do have a few WMA VBR and Ogg Vorbis files that are close to your bitrate there, but those codecs use more battery power to decode than MP3. The vast majority of my files are much higher bitrate…my 4GB +8GB card has 2,224 songs on it. I’ll try to remember to keep track of the time the next time I use the Fuze, but it’ll take a few days to get through it. You might have to remind me though.
Only a suggestion: pick a single mp3 file and let the fuze play it back repeatedly over night or some other time you are not using it - if there is any.
Well, I found one album that is 160kbps, CBR MP3 ( the lowest bitrate MP3 that I have) . The Fuze backlight timer, 10 seconds…brightness is about 33%… volume, about 66% into 60-ohm 'phones. The Fuze is repeating that album (The Doors-Waiting For the Sun) which happens to be on the external card (a SanDisk 8GB class 2 microsdhc ) . When I crash out tonight, which will be about 04:00 , I will make a personal note of battery level and time elapsed, and shut it down. I’ll continue on with it tomorrow.
P.S. After 4 hours it was at 84% battery, although it’s well documented that the battery meter is not exactly linear. Test will continue tomorrow.
@ewelot wrote:
@marvin_martian wrote:
P.S. After 4 hours it was at 84% battery, although it’s well documented that the battery meter is not exactly linear. …
Instead of “well documented” I suspect that it rather has been vaguely guessed - or somehow felt. At least with the latest firmware there is no measurable deviation from linearity. Even the scatter of the individual points matches with PERFECT linearity and the fact that the battery power is given at steps of about 5-6 percent. This has probably not been taken into account by a few users.
Happy listening to another few hours of The Doors … (Yeah, I like this one a lot)
P.S.: I didn’t succeed to insert my battery power plot, grrrrh. Any advise (file formats)? To whom may I address this issue?
Message Edited by ewelot on 05-14-2009 04:50 PM
I’m not listening to it…just letting it run. I’ll look at itafter another 4 hours have gone by, and see where it’s at.You may have a point about this particular firmware , but in the past, both Fuze and Clip have not run down in a very linear fashion…I recently did a FLAC test with my Clip here which illustrates what I meant.
P.S. After an additional 4 hours, the tally stands at… 63% after 8 hours.
Message Edited by Marvin_Martian on 05-14-2009 02:05 PM
Thx for the reference. And there is the plot of the battery running down on my Fuze (mp3, 96kbps, volume 75%, backlight 50% for a total of 20min):
timn brought up a valid point that this could be in it’s own thread, so here we go!
