i am having trouble with my beloved fuse 8g. it’s stuck on the radio the home button works but i can’t change back to music or adjust volum eor station . wheel moves but nothing happens any suggestions on how to fix or do i just need to get a new player… thanks in avance for the help
You may have some schmutz (pocket fuzz, belly-button lint, toe jam, etc.) under the wheel blocking connection with the electrical contacts beneath the wheel, or the contacts themselves may have simply oxidized over time.
I would read and follow the advice in some ofthese threads on the subject of the wheel and cleaning of (and under) it. Note there is good advice and not so good advice, so be sure to read the threads all the way through to ferret out what you should and shouldn’t do. ![]()
Also, just keep in mind that as a last resort, you still have the option to reset this to factory default. If all else fail. ![]()
All resetting the factory defaults does is reset your ‘personal’ settings, like region, screen brighness, auto power off, sleep timer, FM presets, etc. It will do nothing to help the OP’s problem.
