I go into the harddrive and ■■■■ and go to music i open a folder and the music isnt there but on the fuze it is and works fine??? help plz
(also its easier to message me i have a view its my bro with the fuze)
Check the USB mode. Files loaded via MTP mode are not visible to a host computer connected in MSC mode, and vice versa (in Internal Memory - the restriction doesn’t apply to the uSD).
Edit: @7o9 - you beat me to the draw by 1 minute ![]()
Message Edited by daytona955 on 04-09-2009 03:48 AM
So I just saw that they are all there but the songs i downloaded to his fuze arnt in the folder
Again:
There are two USB modes under Settings: MSC and MTP. Your computer can only see one at a time. If you loaded the files in MSC, your computer can only see them if the unit is set to MSC mode. If you loaded the files in MTP, your computer can only see them if the Fuze is set to MTP mode.
The Fuze sees them all, no matter how they were loaded. Your computer doesn’t.
