firmware upgrade??
hi all
i bought the sansa clip yesterday and as of now im happy with it/
firstly i hav the firmware v01.01.11P … as im checkin the forum… i think ver1.1.20 is available
i hav some questions//
1.should i install the firmware 20 directly or do i hav to install like 18 first and then go for the 20
  1. where can i find the list of issues addressed in each firmware upgrade?
3.do i run any chance of “bricking” my clip while doing the upgrade?
4. as i live in INDIA which firmware version should i opt for? (is there a generic ver. for rest of the world other than europe and usa and japan??
  1. would i be able to downgrade the firmware ver. installed if i wish to do so?
  2. my player is chargin ok from say 20-60 percent but once the battrey is charged to 60 percent it takes about 3 hours to charge upto 70 percent ?? is this normal??
thanks all /
Also note, the .11 version did not have the USB Mode selection option either.  Definitely upgrade the firmware.
Don’t rule out the Sansa Updater option either, as this is the simplest method of keeping your Sansa up to date.
Bob :smileyvery-happy:
thanks for replyin guys… help appreciated .
^^^ if ur taking about the USB mode select option … i do already have that option … and i can select the option of either media transfer protocol (MTP) or either the mass storage (MSC) … in my firmware ver 01.01.11P    the player is working in both the cases    PS: as described elsewhere on this forum i am not able to access my songs by “unhiding” any music folder/
when i use MSC a folder named “music” (not hidden) is visible but it has no songs inside. bottomline: MTP mode songs are available
only in MTP mode as per i m concerned/
secondly is there any way i can backup my current firmware from the device … or can any1 provide me with a link to 01.01.11P firmware
in case i hav compatibility issues after upgrading with the us version/
thanks
dont know if u guys already know this or not. … but when ur using radio ur stored presets change with change in the FM profile of settings… so suppose u travel between two cities each with its own radio channels on different frequencies… u can store the presets of each city in differnt FM profiles and change ur FM profile according to the city. Saves u from tuning into wrong presets…
