Extreme PRO SSD card recovery but I dont have the activation licence
Hi I formatted my SSD on the camera, but I forgot to transfer a chunk of files on a specific day and I want to recover the data. I downloaded the rescue pro, but I dont have the activation key with me and I really need this footage. Can I recover the key from the serial number somehow? please help.
(Get Support for Your SSDs and Flash Products | Sandisk)
(Contact Support | Sandisk)
You can’t pull the RescuePro activation key from the SSD’s serial number. Those keys are tied to your purchase, not the drive, so you’ll need to find the original email or contact their support. Since the card was formatted in the camera there is a chance the data is still sitting there if TRIM hasn’t wiped the blocks yet. Just stop using the SSD right away and try scanning it with a proper recovery tool like Stellar Data Recovery which works even without an activation key upfront. Scan once and see if your preview shows up before deciding what to do next.
R-Photo is freeware. Clone your card to an image file on your HDD, then recover your data from the image.
https://old.reddit.com/r/datarecoverysoftware/wiki/imaging_guide
  1. Try free tools first - Start with Recuva or PhotoRec
  2. If files are valuable, consider purchasing legitimate software:
    • EaseUS Data Recovery Wizard (often has discounts)
    • R-Studio (technical but powerful)
    • Disk Drill (user-friendly)
  3. If DIY fails, professional service is your only option
Rescue Pro is not a free tool. If you want a free tool, then go for Photorec or Recuva. And, if this footage is critical, free tools might not be the best choice. It ignores the file system and scans raw video signatures.
Go for Stellar or EaseUS, which has the ability to better video reconstruction for fragmented camera footage and stronger file system repair instead of just raw carving.
