I’ve got a Gigabyte M78SM-S2H, which is AMD-based and uses the NVIDIA 8200 chipset. I’ve been using a standard SATA 100GB drive for a few years in it with no issues whatsoever.
A couple days ago, I dropped in an Extreme 120G drive (SDSSDX-120G-G25) and attempted to put an Ubuntu derivitive on it (the latest XBMC, version 12). The install goes off without a hitch, and it even operates without visible issues for a few minutes. However, things quickly go south, and after a few minutes the machine stops responding.
The motherboard is set to AHCI, and I’ve tried multiple installs on each of the 6 available SATA ports. All result in the same problem. When I switch back to the non-SSD 100GB drive, it works perfectly again. I’m sure the SATA ports are fine.
So I then tried installing Windows, and it too blue screens after the first reboot during install.
It’s worth noting that I have tested this SSD in a Windows 7-based computer (as a secondary drive) and transferred 100+ GB of data back and forth with no issues. This computer is Intel P45 based, and is actually a year older than the AMD-based problematic computer.
I have flashed the Extreme 120GB to the latest firmware (211), and the SSD toolkit shows PASS for all the tests. (This was done on the Windows-based computer.)
Here are some /var/log/syslog entries from my Linux install that appear to show the problem:
Feb 9 14:55:21 htpc kernel: [38.140892] ata5.00: configured for UDMA/133 Feb 9 14:55:21 htpc kernel: [38.141245] ata5: EH complete Feb 9 14:55:27 htpc kernel: [43.677154] ata5.00: limiting speed to UDMA/100:PIO4 Feb 9 14:55:27 htpc kernel: [43.677161] ata5: exception Emask 0x10 SAct 0x0 SErr 0x1910000 action 0xe frozen Feb 9 14:55:27 htpc kernel: [43.677163] ata5: irq\_stat 0x00400000, PHY RDY changed Feb 9 14:55:27 htpc kernel: [43.677166] ata5: SError: { PHYRdyChg Dispar LinkSeq TrStaTrns } Feb 9 14:55:27 htpc kernel: [43.677170] ata5: hard resetting link Feb 9 14:55:28 htpc kernel: [44.400038] ata5: SATA link up 1.5 Gbps (SStatus 113 SControl 310) Feb 9 14:55:28 htpc kernel: [44.421234] ata5.00: configured for UDMA/100 Feb 9 14:55:28 htpc kernel: [44.421587] ata5: EH complete Feb 9 14:55:30 htpc kernel: [46.409123] ata5: exception Emask 0x10 SAct 0x0 SErr 0x1810000 action 0xe frozen Feb 9 14:55:30 htpc kernel: [46.409128] ata5: irq\_stat 0x00400000, PHY RDY changed Feb 9 14:55:30 htpc kernel: [46.409131] ata5: SError: { PHYRdyChg LinkSeq TrStaTrns } Feb 9 14:55:30 htpc kernel: [46.409136] ata5: hard resetting link Feb 9 14:55:30 htpc kernel: [47.132037] ata5: SATA link up 1.5 Gbps (SStatus 113 SControl 310) Feb 9 14:55:31 htpc kernel: [47.153260] ata5.00: configured for UDMA/100 Feb 9 14:55:31 htpc kernel: [47.153613] ata5: EH complete Feb 9 14:55:34 htpc kernel: [50.390466] ata5: exception Emask 0x10 SAct 0x0 SErr 0x1810000 action 0xe frozen Feb 9 14:55:34 htpc kernel: [50.390472] ata5: irq\_stat 0x00400000, PHY RDY changed Feb 9 14:55:34 htpc kernel: [50.390475] ata5: SError: { PHYRdyChg LinkSeq TrStaTrns } Feb 9 14:55:34 htpc kernel: [50.390480] ata5: hard resetting link Feb 9 14:55:34 htpc kernel: [51.112020] ata5: SATA link up 1.5 Gbps (SStatus 113 SControl 310) Feb 9 14:55:34 htpc kernel: [51.132981] ata5.00: configured for UDMA/100 Feb 9 14:55:34 htpc kernel: [51.133333] ata5: EH complete Feb 9 14:55:40 htpc kernel: [56.487416] ata5: exception Emask 0x10 SAct 0x0 SErr 0x1890000 action 0xe frozen Feb 9 14:55:40 htpc kernel: [56.487421] ata5: irq\_stat 0x00400000, PHY RDY changed Feb 9 14:55:40 htpc kernel: [56.487424] ata5: SError: { PHYRdyChg 10B8B LinkSeq TrStaTrns } Feb 9 14:55:40 htpc kernel: [56.487428] ata5: hard resetting link Feb 9 14:55:41 htpc kernel: [57.208026] ata5: SATA link up 1.5 Gbps (SStatus 113 SControl 310) Feb 9 14:55:41 htpc kernel: [57.229055] ata5.00: configured for UDMA/100 Feb 9 14:55:41 htpc kernel: [57.229405] ata5: EH complete Feb 9 14:55:46 htpc kernel: [62.884212] ata5.00: limiting speed to UDMA/33:PIO4 Feb 9 14:55:46 htpc kernel: [62.884219] ata5: exception Emask 0x10 SAct 0x0 SErr 0x1810000 action 0xe frozen Feb 9 14:55:46 htpc kernel: [62.884221] ata5: irq\_stat 0x00400000, PHY RDY changed Feb 9 14:55:46 htpc kernel: [62.884223] ata5: SError: { PHYRdyChg LinkSeq TrStaTrns } Feb 9 14:55:46 htpc kernel: [62.884228] ata5: hard resetting link Feb 9 14:55:47 htpc kernel: [63.608026] ata5: SATA link up 1.5 Gbps (SStatus 113 SControl 310) Feb 9 14:55:47 htpc kernel: [63.632752] ata5.00: configured for UDMA/33 Feb 9 14:55:47 htpc kernel: [63.633101] ata5: EH complete Feb 9 14:55:48 htpc kernel: [65.033137] ata5: exception Emask 0x10 SAct 0x0 SErr 0x1910000 action 0xe frozen Feb 9 14:55:48 htpc kernel: [65.033142] ata5: irq\_stat 0x00400000, PHY RDY changed Feb 9 14:55:48 htpc kernel: [65.033145] ata5: SError: { PHYRdyChg Dispar LinkSeq TrStaTrns } Feb 9 14:55:48 htpc kernel: [65.033150] ata5: hard resetting link
Is there perhaps a known incompatibility with NVIDIA 8200 chipsets?
