this fuze has a error that is code 1003 what do i do to fix this
You got this error code when using Sansa Updater?
yes tried to redo and the same thing
See my post there: http://forums.sandisk.com/sansa/board/message?board.id=sansafuse&thread.id=11163
Basically, Sansa Updater s****, you have to do manual updating, which is why i recommend Sansa people remove Sansa Updater.
Message Edited by kevin02454 on 12-25-2008 07:40 PM
Agreed. If it worked most of the time for all but a few people, that would be one thing; but it appears that more than a few people are having issues with the updater. Just for fun, I tried using the updater yesterday with my new second fuze and I got an error code as well. The manual updating procedure is so easy, I don’t really see a compelling reason to keep the updater.
check the usb setting on your unit change it too MSC on Usb setting
just posted in the sansa firmware updater board
