Does anyone have a problem with their earpiece getting really hot in their ear when listening to the fuze?
no, have you tried other earphones?
No, I am using the ones that come with the fuze.
it may be bad headphones i would try another set and see if the same thing happens
It sounds like a short circuit in the earphones. Stop using it, or you might damage the player.
To say nothing of your ear. You can always buy a new player, but a new ear?
