i connected the sansa to another computer, the computer got stuck. i had to shout down the computer.
since then, its shows reading, and my computer can not recognize it. what should i do?
thanks
I would try a hard reset. Mine was stuck on Connecting and that did it.
Press Select button and Vol + at the same time.
thanks for your reply! i’ll try that next time. it actually run out of battery and fixed it self.
i had just posted a similar problem when i happened upon yours. thank you so much for the help. this was a gift for my younger brother. he will be very happy! thank you again, now i know that these forums are actually helpful. ill spread the word.
