Data Recovery
The reader part of my USB stick has broken. Is there any way I can recover it, it has extremely important data that I need, I cannot imagine what I will do without it.
HI @j79787jr,
Yes, You can use a data recovery tool.
I’m sorry to hear about your broken USB stick and the loss of your important data. I can only imagine how frustrating that must be for you. I had that problem, too. And my friends recommended nwitservices.com to me. They might be able to help you recover your data. They seem to have good reviews. It is important to find a team of experienced technicians who specialize in data recovery and who use state-of-the-art methods to recover lost data. You can try plugging it into a different USB port or even a different computer to see if it’s a problem with the port. If that doesn’t work, you can try using data recovery software to retrieve the files. However, if the reader is physically broken, it may be more difficult to recover the data.
