Dashboard 1.4.1 broken
Hi there,
I’ve just installed a new Sandisk 240GB drive, which is operating fine, but the dashboard software is not.
When run the window looks like an html page without the styling, screenshot here: https://drive.google.com/open?id=0B6wplXOsmxNqbGVKMy1wQm15M1U
I’ve uninstalled and re-downloaded, but have the same issue, running under Win7 64bit.
Any idea what the problem might be?
IIRC the dashboard uses components of IE for the GUI. Make sure you have IE installed and the security settings are set to the default.
Try the following:
Open the registry.
Open the key:       HKEY_CLASSES_ROOT/.css
Change the value of  “contentType” to “text/css”
That did the trick for me.
Many thanks :slight_smile:
