Lately I’ve had issues with a 32 gig cruzer. The flash drive is 32 gigs, but after several formats, Windows thinks it is a 3.14 gig device. Please help! U3 is uninstalled.
Why did you reformat the drive? Whose instructions did you use?
I put Launchpad, noticed software central went down, so I uninstalled U3. And now it thinks it is 3.1 gigs.
you probably used an old version of the U3 installer/uninstaller. download the version in the stickies at the top of this board and use them. they should fix it. or you can search for “hp disk storage format tool” download that and use it to format the drive. either should fix the issue.
