Cruzer Glide
Just got 64b GB cruzer glide. Tried to load 53 GB file  (QT movie) onto 64 GB drive and got message saying file to large? How do I remedy this? Thanks, in advance…
hmmmm Did you format the drive before using it?  I ask because it comes formatted as exFAT which I believe will handle a file that large.
I think that might be the cause. If you can transfer files 3GB but cannot transfer over 4GB, then that will confirm it. <img src=“https://imagicon.info/cat/5-43/1.gif”/>
