Cruzer edge 8gb write protect
how can i removed the error message "write protect’ on my Cruzer edge 8gb.
Have you tried this link?
http://forums.sandisk.com/t5/forums/searchpage/tab/message?filter=labels%2Clocation&location=forum-board%3Aall-usb-ssd&q=write+protect
Hi. If the steps given to you doesn’t help. I’m sorry to say but these are commonly caused by hardware issue. You might need to consider an RMA here.
:smiley:   Hi Ecalingasan,
Dear member of SanDisk Community, welcome.
To understand this problem, see link:
http://forums.sandisk.com/t5/All-SanDisk-USB-Flash-Drives/HELP-how-do-i-reomove-write-protected-message-from-my-16gb-flash/m-p/323924#M8925
Please back up your data, and contact SanDisk Technical Support who will replace the device, if it’s authentic and within warranty.
SanDisk Technical Support: http://www.sandisk.com/about-sandisk/contact-us/
Luck.
Regards, Alfred.        (Google translated)
