I don’t know how it got write-protected. How do I get it back to normal? And, how did it get write-protected anyway?
“how did it get write-protected anyway?”
Nobody knows.
Return it to where you bought it or contact SanDisk for an RMA.
hey many ppl are having same problem. Is there any tool to remove write protection.
plz help sandisk ppl.
No. the only known solution to the problem is to return the drive either to your dealer you bought it from, or to SanDisk directly.
It may be worth it to check the toggle switch, may it’s just right protected. Else, easiest way is to contact tech support.
There is no toggle switch on a flash drive that I know of. ![]()
@Tapeworm sir… what about if the dealer won’t accept anymore?
@ratsadablu wrote:
@tapeworm sir… what about if the dealer won’t accept anymore?
If you re-read my previous post, you’ll notice I said. " . . . to return the drive either to your dealer you bought it from, or to SanDisk directly."
You can call SanDisk Tech Support for an RMA# (Return Merchandise Authorization) and instructions on how/where to return it. ![]()
cruzer edge 16 gb pen write protected help
induwara: “help”
Read posting above your’s.
“” return the drive either to your dealer you bought it from, or to SanDisk directly.“”
