After trying all day using 50 methods trying to remove the error I have read that there is no way to fix this so fuq you to all the people at SanDisk. I’m never buying anything from you again
Hi San_DiskSucsAzz,
Dear member of SanDisk Community, welcome.
Please, do not grieve, friend.
To narrow down the issue, try the pendrive in other computers.
If still giving “Write protection”, is dead, ist kaputt…
Contact with SanDisk Technical Support: http://www.sandisk.com/about-sandisk/contact-us/
If you are interested in the topic, look at the following article:
Luck.
Regards, Alfred. (Google translated)
Did you try using diskpart?
SanDisk will send you a free replacement if you return the drive to them.
