I bought an 8GB cruzer edge to copy some files from an old computer (windows XP) before I wiped it and gave it away. I plugged it in and loaded all the files to the flash drive with no problems. When i plugged it into my Mac (OS X 10.6.8), it worked briefly before i had issues. I was copying files over and got an error message that the disk had been removed without being ejected. Now, it won’t mount to my desktop when i plug it in. I can see it in the system profiler under USB device tree, so the computer recognizes it, but I can’t view/copy any of the files. Of course, the computer i copied the files from is gone, so I really would like to figure out a way to get the rest of the files off the flash drive. Below is what shows up in the system profiler. any help?
Cruzer Edge:
Product ID: 0x556b
Vendor ID: 0x0781 (SanDisk Corporation)
Version: 1.03
Serial Number: 20060164430CF1303975
Speed: Up to 480 Mb/sec
Manufacturer: SanDisk
Location ID: 0xfd100000 / 10
Current Available (mA): 500
Current Required (mA): 200
