A new flash disk does not recognize on the win7 professional 64 bit.
Works with win xp,win7 32 bit home edition,but with my new pc computer not!!
Tried to delete the 0781 files and more.
For nothing!!!
Maybe the sandisk people will organize a link to solve the problem?
anyone who has solved this issue pls. help!!!
Thx,
ed_p
2
Since the problem is limited to the new computer and not the others I suggest:
Delete the files on the Cruzer on one of the computers on which it does work.
Check with the place where you bought the new computer and have them determine why it doesn’t work with the Cruzer.
Check with the vendor of the new computer and have them determine why it doesn’t work with the Cruzer.
If the new computer is a school/university/work place computer ask the IT dept why it doesn’t work with the Cruzer.
I suspect a security setting or app on the new computer is the problem but that’s just a guess.
Let us know when you find a solution.
