I have not been able to get my 32GB Cruze Blade working on my W7 Pro 64 bit desktop. When I plug in the flash drive, this is the message I got:
"Device driver software was not successfully installed
Cruze Blade - No driver found"
Is there something special I need to do with 64 bit W7? This flash drive works fine with 32 bit W7 Enterprise laptop and my MacBook Pro, so I don’t think it’s a defective stick.
Yes, I also tried every other USB port on the desktop and got the same thing. I also tried uninstall the device from Device Manager and then run Scan for hardware changes to reinstall it - still the same result.
Any help is much appreciated!
_ P.S. I also have another 64GB flash stick that exhibit the same problem (no working on W7 64bit and working on W7 32bit and MacBook Pro)._
