cruzer blade 32 gb defect
hi there,
i hv cruzer blade 32 gb, yesterday i plug pendrive to my laptop, after plugging the pendrive error occured “FORMAT DISK NOW”
after formatting, system shows total 2.92 gb memory ofmy pendrive, what should i do,
:smiley:   Hi Lavish,
Dear member of SanDisk Community, welcome.
Please, I need more data, test your pendrive (UFD), in other PCs, and tell me what happened.
Try on your PC, other pendrives, and tell me what happened.
This is the first step, to know where is the problem.
Luck, and then you tell us, what happened, please.
Regards, Alfred.                                 (Google translated)
90% chance, it’s a dead stick already. Or may be a used one too. Try to reformat it too and see if it makes a difference.
 :confounded:
Hmm… Again!
Hmm… is there an echo, distorted… (and 3 days later…)
Well …at reviewing others posts and user accounts, I found this…
01- beiker          -------> (01-02-2012 to 18-03-2012), (29-12-2013)
02- Kuerten               -> (15-03-2012 to 21-06-2012)
03- peleus                 -> (21-06-2012 to 16-08-2012)
04- mithcd                  -> (16-08-2012 to 15-12-2012)
05- austingrd             -> (19-12-2012 to 10-02-2013)
06- doncht                  -> (14-02-2013 to 30-03-2013)
07- dwaynnyt              -> (31-03-2013 to 26-05-2013)
08- rickyjm                  -> (09-05-2013 to 25-10-2013)
09- jimmyghd            -> (29-10-2013 to 28-12-2013)
10- mikkirourke         -> (03-01-2014 to 02-03-2014)
11- markwahl             -> (07-03-2014 to 27-04-2014)
12- kitscht                   -> (28-04-2014 to 06-06-2014)
13- Hirsche               => (07-06-2014 to     … Now …  ) <=
hmm… (IP… idem?  mac… idem?)
Hmm… Again!
Certainly seems that way.
http://forums.sandisk.com/t5/All-SanDisk-USB-Flash-Drives/Cruzer-Vault-works-once-but-not-twice/m-p/326162#M9123
:dizzy_face:   OK!!
Ed, comprendí su atento consejo, y estoy depurando mis mensajes.
Por favor, podría borrar su mensaje, así yo borro el anterior y luego éste.
Ed, I realized attentive advice, and I’m debugging my messages.
Please, could delete your message, so I remove the previous and then this.
Gracias.
