dont know if this makes a difference, but when i go into “my computer” the cruzer drive shows a different icon, not the standard grey/white “drive” icon, instead its a white page with a small “windows” page with a blue taskbar.
it DOES show as a removable disk.
Update: the Secureaccess manager icon now shows on the taskbar at the bottom, but it doesnt work. When i left click, nothing happens. When i right click the only options are “about”, “exit” or “disable notification”.
there seems to be a small blue circle in the bottom right of the vault icon, but its too small to see. not sure if this has always been there, but i dont think so.
