What exact WinAvi program did you use? I tried the free version of “WinAVI 3GP/MP4/PSP/iPod Video Converter” but could not change the codec. It allowed me to change everything else. Maybe because it was the free version. Did you use the SMC to transfer to the Fuze? I would like to try before I buy because I have already been burned by buying another program that did not work. Know I know why people buy Mac products. Sansa deserves to get trashed in the “Video” portion of this device in Amazon.
@abacot: I did not use SMC at all, i copied the converted avi file directly to the Sansa Fuze. I added the correct link and version number to “WinAvi Video converter v8.0” above. WinAVI 3GP/MP4/PSP/iPod Video Converter is not the same package!
I’m gonna try your method Symen. Will report back soon
Edit: Ok I tried it, and it worked but I can’t fast forward through the videos …
Also, if you pause it and resume playback it will stutter
Message Edited by codeformoney on 11-30-2008 01:55 PM
Edit: Ok I took the video that WinAVI converted and run it in Sansa Media Converter and everything is good… sound/video are in sync and I can fast forward/resume playback with no problem. But the quality seems to be reduced but not that much noticable, I’ll try different settings and report back
Message Edited by codeformoney on 11-30-2008 02:12 PM
Ok what I did to convert videos that are in sync (video/sound).
I have the latest K-Lite Mega Codec
1. Convert the movie in WinAVI with these settings:
Codec
Video: ZJMedia MPEG-4 Encoder
Audio: ZJMedia Mp3 Encoder
Video framerate
Video framerate: 20
Picture size
Keep original height/width Audio
Sample rate: 44100
BiRate: 192000
2. Take the converted movie from WinAVI and put it in the Sansa Media Converter and convert again.
3. Your movie should be in sync (video/sound) now with no errors.
Message Edited by codeformoney on 11-30-2008 03:40 PM
Has anyone else experimented with WinAvi and the FUZE?
for me, it works (without SMC :smileyvery-happy:)but I can’t fast forward (the fuze returns to the menu when I do so)
I’ve tried different formats and encoders to no avail.
no one? really?
No response because you really had no questions. You asked one and then you said it works. Why should we respond to something that works? Thats Great! You are better off than some! Also If you do a Search of this board, you will see that the top 2 things we recomend to try are:
I tried to convert a 1.5hr movie using Any Video Converter into an “.avi” with the settings listed above and it did not work.
First, I transfered the “.avi” straight to the Fuze, but I got a message that said the file was not compatible.
Second, I dropped the “.avi” into SMC. The video played, but there were sync probs right from the start.
I have a feeling that this has a lot to do with the video length. SMC can handle anything small (maybe 10-15min or less), but anything more than that it just does not sync. I have had no prob with short vids, but movies are another story.
