Can I connect a Sansa Clip Zip to a DVD/CD player, or a speaker to play in a room?
As long as you have (or can find) a cable with the appropriate plugs on both ends, an 1/8" (or 3.5mm) plug for the headphone jack on the Zip and whatever your speaker(s) or other device takes. Note your DVD/CD player or any other device will need to have an AUX IN jack or some way to receive the signal.
Thanks for the info!
