I have my wireless stick working perfectly on my iPhone and iPad. But I can’t seem to connect from my pc in the way suggested n the manual. When I go to www.sandisk.com/my connect. I get a webpage that suggests that it is not turned on. However I know it is . I can connect using the IP address as reported on my iPhone. But I cannot connect using the URLs.
you cannot have an Internet connection on the PC and connect to the wireless stick. If you see a page telling you to turn it on and connect you have Internet connection as this is a webpage.
You will need to connect to the wireless stick network. If there is an Ethernet connection it will need to be disabled ur unplugged.
again this means you have an Internet connection present on the pc. this is why the /myconnect url is resolving to the not connected page. If you can still get to it using the IP you can use that using the ULR requires that there is no Internet connection present on the PC.
Thank you for the above posts. Bring clarity regarding the usage.
My Sandisk Wireless 32GB connect well with my Phone, my PC, and my TV for watching movies wirelessly. Here is the setup i currently use-
Sandisk Connect to my existing Wifi Network.
I use Phone App (Android) to access file on Phone or on TV.
I’ve to use standalone connection with PC for accessing data wirelessly on my PC in case of which I cannot access my Internet. Secondly i simply plug in to my system in case of which i cannot use the stick wirelessly for my phone.
I was trying to figure out a way to resolve following issue or rather my requirement for more efficient use of My Sandisk Wireless Connect Drive.
When I connect my Sandisk Drive to Wifi network, I can access data on my phone through Android App. However, I cannot connect my PC to access data on the wireless drive. Obviously, im connected to internet and www.sandisk/myconnect wont recognize the wireless drive. Here i saw that my existing Wifi Network allocates a IP Address to Wireless Drive. When I try accessing the IP Address allocated to Wireless Drive. ie. 192.169.xx.xx it routes to " 192.169.xx.xx/myconnect". Here it asks of “User ID & Password” to access the Myconnect page. Have tried multiple combination but failed.
Benefits: - I could access my wireless drive streamlessly on my Phone & my PC wirelesslely alongwith access to internet.
If the above scenario is successfuly, i would wish to add the wireless drive as wireless network drive on my PC (which i have been successful to do so when connecting standalone to PC) so i could seamlessly work on all my data on Sandisk Wireless drive. Let us say accessing excel spread sheet file on PC from wireless disk and working on it and saving it back on wireless disk.
Would extremely appreciate your valuable view on above.
The instructions posted in the previous message make NO sense to someone new to the SanDisk product line. “Connect to the SanDisk network…” With WHAT? The app or the PC? Connect to the local wireless network? With what? The PC or the App. PLEASE… SOMEONE WRITE SOMETHING with some CLARITY. Thank you!
To ensure that it’s fully charged. A full charge can take up to 2 hours. The device cannot be connected using a USB cable. Plug your Wireless Stick into a computer USB port or a USB AC adaptor* to charge it. 192.168.1.1
Thank you for posting such a great article! I found your website perfect for my needs. It contains wonderful and helpful posts. Keep up the good work!. Thank you for this wonderful Article! five nights at freddy’s
I was born in united states but grew up in New York. happy wheels. These are probably my two favorite games of all time, and I’m trying my best to make it in the top 1-3 of google. fireboy and watergirlGeometry Dash
Make sure that your USB Flash drive is connected to your local/home Wi-Fi network.
Get your USB Flash drive current IP address (either from your router DHCP client list or using USB mobile app, about tab)
Enter in your web browser in the address bar http://X.X.X.X/files, where X.X.X.X is your flash drive IP.
Browser will require a username and password (Trick is here) Username is defualt by SanDisk ( owner ) while password is your flash drive Wi-Fi password, IF you set a Wi-Fi password to your USB Flash drive then the password to http will be your Wi-Fi password , If you did not set a Wi-Fi password leave it blank.
Thats it! Cheers, Enjoy…
Note: Files access is limited via HTTP only, You cannot add the device to be accessed wirelessly through windows explorer as a network or mapped network drive.
Thank you for your sharing. This method work successfully. But I have another question about upload the files. When I drag the files to the folder which shown the box of “can’t find this item” After refresh the folder, the file is already in and the size is 0Kb. Do anyone have recommend to solve this problem? Thanks
On my laptop, connected to my own wifi (not sandisk wifi)
* I’m able to access files on browser like this http://192.168.0.19/myconnect/. I can also do everything (add files, delete, etc). Everything good here.
* I’m also able to access it by UNC like this \192.168.0.19\myconnect on windows explorer. I’m able to delete but I"m not able to copy/add/edit files to it. I get “The parameter is incorrect” error. Do you have a solution to this issue?
One day her curiosity won against common sense and she decided to break down her boundaries. She left home and entered a forest after the sun went down. Lost and afraid in the new world geometry dash
