I’ve recently purchased a clip zip with a 32GB micro SD card
I’ve tried a number of ways of transferring the music onto the Zip, either by dragging and dropping or syncing with the Banshee music player. However, each time when the zip states ‘refreshing your media’ the progress bar only gets a short way across before the music player shuts down.
I’ve read on this forum and elsewhere that this is a probably an issue with tags. I’ve tried to use EasyTag, but I can’t see what the problem with the tags is.
I’ve tried using MP3Tag but it won’t let me change the tags - I get the error message ‘cannot be opened for writing’. I’m following the instructions here and trying to delete non essential tags
Perhaps your files have become corrupt. Assuming your files are in mp3 format, you may be able to repair them with MP3Diags. Or you can try to get them from wherever they came from in the first place.
A lot of the tags said ‘cannot be opened for writing’ but I just pressed ‘Yes’ to continue and to skip over those ones. The others were changed and now my Sansa Clip works perfectly.
You can try Kid3 to edit your ID3 tags in the linux environment. Here’s a handy [comparison](/t5/forums/replypage/board-id/ClipZip/message-id/) of tag editors I found.
The link for Kid3 is here. Under the download section, you’ll see an Ubuntu package.
The can’t be opened for writing probably means the file is open with another application(perhaps Windows Media player or some other media player)? It happened to me a few times until I realized what was causing it.
