I just bought the clip sport but there is one problem. When I connect a usb cable to charge it, it will not power off. I press and hold the power button and it briefly powers off then turns right back on. When I’m not charging the unit it will power off. Whats the deal with this silly thing. Any ideas how I can shut it off while charging.
Only one?
Consider yourself lucky. ![]()
That’s the way it’s supposed to work. All SanDisk mp3 players are the same way… See, you didn’t have a problem after all. Now you really ARE lucky! :smileyvery-happy:
You just bought it? Okay, do this:
Go back to store;
Refund you Clip Sport
Buy a Sansa Clip
Be happy
