Hi All!
I’ve downloaded the manual for the clipsport and can’t find referance to the FM radio function anywhere. Anyone give some info on how to access the FM radio functions?
Hi All!
I just bought this device. I bought it for the radio function, and I can’t even find the main menu. Help!
It might be that you haven’t peeled off the protective screen film/sticker, and are seeing a “screen-shot” image that doesn’t change instead.
If those have bought the MP3 player knowing it has the capability of a FM tuner when they asked on how to get into the radio mode as like any other personal audio device the antenna is part of the cable for the headphones and or the earbuds.
If you do not have the radio icon on your screen go settings, then system settings, then Customize. Click down to radio and turn it on. Your radio icon should show up then. To tune, use right and left arrow keys to get to a station.
