Clip + FM Radio Volume Way Too Loud
When I switch to FM radio and put it at the minimum volume setting, the radio is still REALLY loud!!!
I’m at the most current firmware setting, according to my SANSA update software.
Is this volume issue being addressed?
SanDisk is aware of the problem and working on it. The same issue was present in the original Clip and it was fixed with a firmware update. Until the same happens with the Clip+, you can buy a headphone jack extension cord at Radio Shack with an in-line volume control on it for about 10 bucks.
http://www.radioshack.com/product/index.jsp?productId=2272471&CAWELAID=107596442
