This is my second clip. the first one i rma’d for the exact same problem. basically i charge it full…listen to it randomly for about 6ish hours (5 sec backlight with little time spent interupting playback). The battery shows its still 2/3 full then all of a sudden it will shutdown due to lack of charge.
I can’t imagine this is normal and i would expect to get at least 10 hours of playback. Right now i would estimate around 7ish hours max of music playback. Did i get a second dud in a row or is this common? I hate to rma another one but 7 hours of playback is unacceptable.
If it will help i use the custom equilizer setting, listen mostly to .wma format, volume around 1/3, 5 sec backlight with backlight around 50% setting. I usually listen to it falling asleep for a couple hours at a time and rarely foreward a song etc…that would cause the backlight to come on. it lasts for three nights and died early on the fourth so approximately 7ish hours of playback.
thanks for any help.
