Is there a way to charge on usb & listen to it? I bought it to mount on my motorcycle, haven’t opened it yet (Christmas present), was thinking battery life didn’t matter because I have a usb charger on the bike I can leave it plugged in. If not, is there any way to charge & play at the same time? May have to return it…Thanks
You can charge and play at the same time with external non-computer power. I think that this will meet your needs. You can also charge and play via your computer if you use a power-only USB cable or otherwsie block/don’t attach the data pins in a regular USB cable.
And motorcycles now come with USB connections? Wow!
I think you’re set!
You can charge and play at the same time with external non-computer power. I think that this will meet your needs. You can also charge and play via your computer if you use a power-only USB cable or otherwise block/don’t attach the data pins in a regular USB cable.
I think you’re set!
Is it normal for the Clip+ to shut down itself while charging off wall-usb adapter? If i charge via pc usb, it stays on as long as it’s connected. While connected to wall charger, it shuts the screen off after ~ 30 mins. If i start the player, it shows charging. Is this normal?
Yes
hi
something wrong has happened to my sansa clip 2 gb
i connect it to my pc . it only charges … doest get sync with the pc…
i am unable to load songs… is there a problem with the white cable provided with it. or is there any separate cable i can use to load mp3 songs on it…
kindly help
When connected, the OLED display of the Clip+ will turn off after one hour to save the display.
µsansa
