Just got my new Sansa Fuse. When turned it on discovered that the mail language us Chinese. How can I change it to English?
On the player’s menu you would choose settings, language. Unfortunately if you can’t read Chinese, you won’t be able to read the player’s menu to do this(There is also a menu setting in sttings to restore the factory settings) The solution is to download the firmware and load it on the player. When the firmware is first installed, the language is English until it is changed to something else. You can search this forum to see how to update the firmware.
Turn on the Fuze
Press the Home button to get the top menu (rotating, with icons)
Spin the wheel till the thing that looks like a mixing desk with 4 sliders is at the bottom.
Click the centre button
Spin the wheel to select the 6th item (bottom one on my Fuze) - system menu
Spin the wheel to select the 6th item from the top - language menu
- now you should be in the language menu English is the first menu item (on mine)
Click the centre button.
Good luck!
